Perform this procedure to view information about the operating status of the power supplies.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Power Supply.
  3. Select the Detail tab.
Detail Field Descriptions
Use the data in the following table to use the Detail tab.
Name
Description
Type
Describes the type of power used.
Note: To know what power types the switch supports, see the hardware installation documentation.
Description
Provides a description of the power supply.
SerialNumber
Specifies the power supply serial number.
HardwareRevision
Specifies the hardware revision number.
PartNumber
Specifies the power supply part number.
PowerSupplyOperStatus
Specifies the status of the power supply as one of the following:
  • unknown
  • empty
  • up
  • down
InputLineVoltage
Displays the input line voltage:
  • low110v—power supply connected to a 110 Volt source
  • high220v—power supply connected to a 220 Volt source
  • ac110vOr220v—power supply connected to a 110  Volt or 220 Volt source
OutputWatts
Displays the output power of this power supply.
VoltageIn
Specifies the input voltage value in millivolts (mV) for the power supply unit.
Specifies the output voltage value in millivolts (mV) for the power supply unit.
CurrentIn
Specifies the input current value in milliamps (mA) for the power supply unit.
CurrentOut
Specifies the output current value in milliamps (mA) for the power supply unit.
PowerIn
Specifies the input power value in milliwatts (mW) for the power supply unit.
PowerOut
Specifies the output power value in milliwatts (mW) for the power supply unit.
